Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
I get a window askin me whic polling engine to use
bripage
I installed Orion on another server in my network to test out the Database back and restore features. After I was finished I uninstalled Orion and then deleted the sql database that I had used to do the back/restore testing. Now, when I go on the original Orion server and load the Orion Network Performance monitor... I recieve a window that ask me which polling engine Id like to connect to. What I want to know is how do I make sure that I dont get this window anymore. Basically, what do I need to do in order to make sure that it no longer thinks the other server is still al polling engine?
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Run the Polling Engine Load Balancer app & remove any references to the test server:
www2.solarwinds.net/.../topic.asp
-=Cheers=-
NG
bripage
ok... but were is that located?
Network_Guru
I believe it is an add-on, downloadable from the customer downloads page.
-=Cheers=-
NG
mjhamilton
I had this problem when migrating from my test server to my prod server.... the management tool allowed me tool delete the extra polling engine and then it just reappeared next time around.. was very upsetting.... this was the fix i used in the end
Have more fun than you had yesterday
Martin J. Hamilton... lost in a sea of snmp...
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
