This is all new to me- I need to monitor certain counter that are under PERFMON that we do annually.
richmc06,
If you want to monitor perfmon counters, this collection is usually done with the WMI protocol. In order to do this in Orion, you will want to add the Orion Application Performance Monitor (APM) module onto your Orion. The cool thing about this module, is when you add it in, it adopts all the reporting, alerting, mapping and other features in Orion NPM - so it's fully adapted into your monitoring solution.
Thanks, Jason HensonLoop1 Systemswww.Loop1Systems.com
first - do you have Orion APM?
