HI Guys,
I am looking at a 99% untilization on a gigabit port on the switch but the interface bandwidth auto settings has it at 1.0kbps? How has NPM decided this interface bandwidth?
It looks at the actual interface speed or bandwidth statement. But if they're both correct, you can just manually overwrite what NPM has configured. Just click on Edit Interface.
I am seeing the same problem in 2 new SG-350 switches running version 2.4.0.94
Interface bandwidth set by NPM to 0.001 mbps
Changing it for 26 interfaces per switch is cumbersome and non sense
This is a bug for the SG-350, listed under CSCvn42104.
Looks like it may be an open item. The Cisco bug site is blocked if you search for it, this is the closest I could find.
Re: CSCvn42104 - On SG350 Interfaces ar... - Cisco Community
Workaround would be to go into Manage Nodes, Expand out the Nodes and select all Interfaces where you can change the speed for all Interfaces, or change the Nodes Drop-down to Interfaces and search and select the Interfaces to set the Interface Speed.
Thanks! That explains it!
