I just wanted to mention I've opened case # 75635 for an issue I'm having with alert suppression. I've created an alert to notify if "critical" interfaces on routers go down. The alert triggers if the interface is "Not Equal" to Up. I had to include a supprression if the node was unmanaged otherwise unmanaged nodes will trigger in the alerts. There appears to be a bug that doesn't like suppressing an alert based on node when you're monitoring the interface.
