Hi everyone, just started using Solarwinds Orion - having a ton of trouble getting Extreme network boxes added with SNMPv3. Below is my config:
configure snmpv3 add user nms authentication sha <redacted> privacy aes 256 <redacted>
configure snmpv3 add group orion user nms sec-model usm
configure snmpv3 add access orion sec-model usm sec-level priv read-view orion notify-view defaultNotifyView
configure snmpv3 add mib-view orion subtree 1.3.6.1.2.1.1 type included
configure snmpv3 add target-params user user nms mp-model snmpv3 sec-model usm sec-level priv
disable snmp access snmp-v1v2c
disable snmpv3 default-group
disable snmpv3 default-user
For whatever reason when I add this node, it keeps saying "test failed" - I can ping back and forth between the snmp server and the switch, so I am not sure what the problem is. Has anyone had any luck/trouble with this vendor?
