I'm exploring WMI and SNMP to obtain fan/temp of some of our PC's. I am using a local tool called speed fan
http://www.almico.com/speedfan.php
It is amazing, but only runs locally and I was wondering how it get's its information. I have run WMI explorer and can't locate the temps and tried using SNMP. THen I thought if speedfan was running locally can snmp/wmi grab this info from speedfan itself?
