hi,
i have orion 8.5, i want to move it to another server..., i installed everything,how do i transfer all the the configuration from the old server to the new , what is the conf. file i need to copy ? how do i transfer all the maps ?
thanks
Roee
These steps are detailed in this pdf.
www.solarwinds.com/.../OrionServerMigration.pdf
the maps were mifgrate with no problem , but how can i migrate the System manger conf. - with all the nodes i did there?
Please advise.
The configuration of the nodes which can be browsed through system manager is in the database.
If you moved Orion to another box then it created another entry in the Engines table and you need to follow the step "Reassigning Nodes" in the guide Mark gave you in his post.
-Yann
hi
thank you for your response.
i am doing exactly like it is written.
i am restoring the back file from the old server (i copied it to my new server deskto), go to the Engines Query, but i can see only the new server.(i shutdown the everyting on the service manger except the SQL express).
when i am changging the name of the server and turn on the server manger , i have two servers...(but they are the same).
the nodes are still empty.
is there a way just ot take the nodes and copy them to the System manger ?
ROee
