Hello, I haven't been able to find a way to create a report that will display disk IOPS with report writer. Is this possible? If so, how would I go about doing it? Thank you!
APM statistics are available in reports in v3.0. Go to New Report and you'll see APM: Historical - Statistic of Components.
Well I don't think so but I hope someone with Solarwinds reads this and says differently.
I have APM (I assume you do also) and I've defined some WMI objects to monitor disks but the property APM calls "Statistic Data" is not saved or available to Report Writer.
The best I can do is do an alert on thresholds through APM. It really lacks in doing historical trending.
