Hi All,
Below is an SQL Query we have modified such that it will aggregrate all the ingress flow for multiple MPLS links but the source / destination IP can only those we are intrested in. It will basically list the Top 10 Applications which matches them.
What we are looking for for each of the Top 10 applications, we want to know the Top 10 conversations they have.
Hope somebody has done it before and we can use it
THanks
Hari
SELECT TOP 10 NetflowApplicationSummary.AppName AS Application_Name,
NetflowApplicationSummary.Port AS Port_Number,
SUM(NetflowApplicationSummary.TotalBytes) AS SUM_of_Bytes_Transferred,
NetflowApplicationSummary.Protocol AS Protocol_Number
FROM
WHERE
( DateTime BETWEEN 40552 AND 40553 )
AND
(NetflowApplicationSummary.InterfaceIDRx = 37) OR
(NetflowApplicationSummary.InterfaceIDRx = 35) OR
(NetflowApplicationSummary.InterfaceIDRx = 8) OR
(NetflowApplicationSummary.InterfaceIDRx = 11) OR
(NetflowApplicationSummary.InterfaceIDRx = 3) OR
(NetflowApplicationSummary.InterfaceIDRx = 4) OR
(NetflowApplicationSummary.InterfaceIDRx = 71) OR
(NetflowApplicationSummary.InterfaceIDRx = 70)
AND
(NetflowApplicationSummary.SourceIP LIKE '10.88.84%') OR
(NetflowApplicationSummary.SourceIP LIKE '10.88.85%') OR
(NetflowApplicationSummary.SourceIP LIKE '10.88.86%') OR
(NetflowApplicationSummary.SourceIP LIKE '10.88.87%') OR
(NetflowApplicationSummary.DestIP LIKE '10.88.84%') OR
(NetflowApplicationSummary.DestIP LIKE '10.88.85%') OR
(NetflowApplicationSummary.DestIP LIKE '10.88.86%') OR
(NetflowApplicationSummary.DestIP LIKE '10.88.87%')
GROUP BY NetflowApplicationSummary.AppName, NetflowApplicationSummary.Port, NetflowApplicationSummary.Protocol
ORDER BY 3 DESC
