Hi All,
Is it possible to set different ICMP and SNMP timeout/re-try settings for separate devices? I currently don't see that option. Once the device is added and for instance we need to modify the timeout or retry settings then there is no override option available.
While adding via Sonar discovery, it does show the default settings and allow to change but then will this be applicable when the next polls occurs?
