This only happens after applying upgrade for NPM 9.5 SP2. Please see attached screenshot
The issue seems to only happen with Microsoft Windows Loopback Interfaces.
Do you need to monitor these interfaces?
I suggest you remove them in Orion. (Web Console > Admin > Manage Nodes.)
The issue seems to be that Orion discovers a specific speed for the Loopback interface (e.g. 100Mbit/s) but this one can basically go above the speed discovered till it reach the bus speed.
HTH,
Yann
