Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Determining what OID is being read
jimmo
Hi All!
Sorry, if the question has been asked before, but I could not find it in the doc,in the online help or doing a search of the forums.
In Orion Network Performance, version 7.7, I am trying to figure out how it calculates the various values. Particularly, I am interested in finding out what OIDs are read. I was told that it uses the Host Resource MIB, but obviously many of the values displayed are calculated and not part of the MIB (at least as far as I can see).
Also we are getting values that do no appear to make sense, so it would be helpful to know what OIDs are being read. Where can I find out which OID are being used.
Any help is greatly appreaciated.
Regards,
Jim Mohr
Find more posts tagged with
Accepted answers
All comments
BK
The Host CPU poller will first try to poll the processor utilization using the Host Resource MIBs hrProcessorLoad (1.3.6.1.2.1.25.3.3.1.2) column. If the MIB is supported, then the column is read (one row for each reported CPU) and the values averaged. If hrProcessorLoad is not supported, then Net-SNMP MIB variable, ssCpuIdle (1.3.6.1.4.1.2021.11.11.0) is tried. If a response is received, the value is subtracted from 100 and saved as the CPU load. A flag is then set marking this host as a Net SNMP Agent.
Next Memory is polled. If the node responded to the Host Resource MIB, hrMemorySize (1.3.6.1.2.1.25.2.2.0) is polled and used as the Total Physical Memory Size. Finally, the hrSWRunPerfMem (1.3.6.1.2.1.25.5.1.1.2) column is retrieved and the amount of RAM being used by each process is added together to determine the used memory. This will result in memory utilization greater than 100% if you have paged RAM out to disk. By allowing the utilization to be larger than 100%, an administrator can measurement of how much the RAM is overcommitted.
If Net-SNMP was detected, then memTotalSwap(1.3.6.1.4.1.2021.4.3.0), memAvailSwap (1.3.6.1.4.1.2021.4.4.0), memTotalReal (1.3.6.1.4.1.2021.4.5.0), memAvailReal (1.3.6.1.4.1.2021.4.6.0) are polled. Used Memory is calculated as memTotalSwap – memAvailSwap + memTotalReal – memAvailReal. For Total Physical Memory Size, the value of memTotalReal is used.
Hope this helps.
BK
Nobody Special
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
