quote:Originally posted by MrSNMPBrent,95th percentile is the threshold where 95% of the data points fall below this level. While the data would certainly be more accurate from a usage standpoint if you had at least 30 days of statistics, you can calculate the 95th percentile on very small data samples.Whether you add the in and out is up to you. Is it a half or full duplex circuit? How is the customer billed (traffic sent, received, etc..)?On the last item, that sounds like a bug to me.--HTH
