Hello all,
I have the problem that two tables are growing out of any proportion:
- APM_ProcessEvidence_Hourly (50.8G)
- APM_ProcessEvidence_Daily (20.8G)
and are now almost half of the size of my overall db of 150G.
Looking at the maintenance log I see the following error, which I think is in relationship to the unstopped growing of the two tables:
2011-07-13 02:16:20,490 [1] INFO SolarWinds.Data.DatabaseMaintenance.MaintenanceEngine - Summarizing detailed data from APM_ProcessEvidence
2011-07-13 04:14:14,291 [1] ERROR SolarWinds.Data.DatabaseMaintenance.StandardTableHandlerDAL - Failed to execute procedure: apm_dbm_APM_ProcessEvidence_DetailToHourly
System.Data.SqlClient.SqlException: Violation of PRIMARY KEY constraint 'PK_APM_ComponentStatus_Hourly'. Cannot insert duplicate key in object 'dbo.APM_ComponentStatus_Hourly'.
Warning: Null value is eliminated by an aggregate or other SET operation.
The statement has been terminated.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj)
at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj)
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result)
at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe)
at System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
at SolarWinds.Data.DatabaseMaintenance.StandardTableHandlerDAL.InternalExecuteStoredProc(String procedureName, SqlParameter[] parameters)
2011-07-13 04:14:14,306 [1] INFO SolarWinds.Data.DatabaseMaintenance.MaintenanceEngine - Summarizing hourly data from APM_ProcessEvidence
2011-07-13 04:26:57,265 [1] ERROR SolarWinds.Data.DatabaseMaintenance.StandardTableHandlerDAL - Failed to execute procedure: apm_dbm_APM_ProcessEvidence_HourlyToDaily
System.Data.SqlClient.SqlException: Violation of PRIMARY KEY constraint 'PK_APM_ComponentStatus_Daily'. Cannot insert duplicate key in object 'dbo.APM_ComponentStatus_Daily'.
Any ideas on how to fix it, it starts to get near to the disk limit. Not really wanting to just drop the tables.
best regards,
Andreas
