I'm building a Network Atlas map using several custom pollers. I've set custom poller thresholds, so the poller object icons reflect the poller status. But I'd also like to add a label to the poller object to show the current poller value.
As you can see from the image, when hovering over the map object, I get the poller value. The problem is I don't know the name of the field in the DB to call as the variable in the label. Does anyone know how to do this?
