Hi all , how may services can monitor using NPM sl100 , what i mean is up and down alert, Bandwidth etc?
Hi sivakumars, to the best of my knowledge NPM SL100 means the limit of your elements (nodes or interfaces or volumes) is restricted to 100 (nodes < 100, interfaces < 100 & volumes < 100 ). It has nothing to do with your alerts. But you wont be able to add more than 100 nodes or interfaces or volumes
Baseline is you can have 100 nodes + 100 volumes + 100 interfaces in your environment.
Hope it helps
SL100 is 100 things, not 100 of each thing..
i.e. #nodes + #volumes + #interfaces <= 100
I confirm Vinay's answer. I'm not sure if you're running Netflow or SAM but i'm feeling like you should check them out if not.
