Hi all,
I have tried to alter my existing orion datase collation, just follow this article:
https://support.solarwinds.com/SuccessCenter/s/article/Supported-SolarWinds-Orion-database-collations-for-Orion-Platform-2015-1-or-later
I used second method in this article, when i execute the command, it's interrupted by some error. See detail in this post:
https://thwack.solarwinds.com/thread/130427
Someone suggested me using first method in the article, that is:
- Create a backup of current database
- Re-install SQL instance with a supported collation
- Re-create tables
- Import data from old databse's tables
And I found someone else encounter the same issue, he finally ended up with setting up a new system and copied over the Data by an API Script.
Alter SQL Collation of Solarwinds Database
So I want to konw how to copy data between two orion databases by API script. Anyone could help me or give me some reference documentation?
