Hi All, I came across a very strange bug in Solar winds which is causing to show volume utilization 2847%.
I went more inside to check why it is appearing like this then I found that-
1. Drive was initially 1.8 PB(Pico Byte) and its calculation was based on this value.
2. Drive Size was later reduced to 70 TB and from there all the calculations went wrong.
I don't know how and where solar winds has configured the logic to calculate the percentage Utilization, otherwise I would not have ended with deleting the volume and then again adding it.
Do anyone came across similar issue.
