I have a few issues. Running NPM 9.5.1, NTA 3.6, and APM 3.1. Orion Server is Server 2003 SP2 32bit, talking to dedicated SQL 2008 DB on Server 2008 x64. All is working fine, except when I look at the Polling Engines application, it shows a red dot and that it is down.
Another question, as I'm running dedicated SQL, does the Windows Internal Database still need to be running on the Orion Server. That shows as service option to start or stop from the Orion Services application.
Finally, when I log into Orion from home over our VPN from a Windows 7 x64 PC, I constatly get the pop up for the Solar Winds Toolset API. I answer yes or no but it does not matter. It keeps popping up after every page refresh. Very annoying.
