quote:Originally posted by mgibsonI have not set-up any Alert supprestion under the v7 Alert Engine. I would like to start using Alert Supression using the V8 Alert Engine. However I am finding it hard to understand how its works. I have a very large, very complex network and do not know where I should start. Are there any best practices available for Alert Suppression? If I understood the basic concepts for each type of suppression scheme, I would possibly understand it. Does anyone whom is currently using suppression possibly explain it to me?Thanks
quote:Originally posted by ckoreI believe the Orion software engine polls devices randomly so even if you have alert suppression enabled on a router, it may poll and alert off downstream devices first. Alert suppression really will not work in Orion properly until they allow you to configure the polling sequence appropriately.
quote:Originally posted by mgibsonI have done what was suggested and devices downstream now have a polling rate of double that of the upstream router. When setting up the alert suppression, how does it know to suppress alerts from the devices on the down stream side of the router as I have not identified which devices are downstream? I configured the alert using the older engine, not the beta.I am still struggling on the correct setup using the beta.
