Is there any way to drop a link to another map for navigation purposes but not report the 'status' of that link, such that I end up in a status loop?
Currently, if I drop a 'go-to' an upper level map, and a sub-map of the parent has issues, the status of a leaf map feeds back down to the other leaves. Turning the map properties status slider from 100% to some other value sort of fixes the issue, except I want everything on the map to report it's status, except the go-to icon.
This is to allow a drill-down into a down node, but also allow navigation to drill-UP back to the parent maps. I don't want the status of the parent map to reflect on the child map, however.
