OS Info.
This query will pull the information you need for your report only information about nodes that are not ESX hosts:
select N.Caption as [Node],Count(N.AssetInventory.Processor.Name) as [Total CPU Sockets],Sum(N.AssetInventory.Processor.NumberOfCores) as [Total CPU Cores],Max(N.AssetInventory.Processor.Manufacturer) as [CPU Vendor],Sum(N.AssetInventory.Processor.NumberOfCores)/Count(N.AssetInventory.Processor.Name) as [CPU Cores Per Socket]from Orion.Nodes NWHERE N.VirtualMachine.VirtualMachineID is NULLGroup By N.CaptionHAVING Count(N.AssetInventory.Processor.Name) > 0ORDER BY N.Caption
Hi M-Milligan,
Really fantastic. Thank you so much for your valuable answers. Its working.
ESXi (VMware) devices details are not showing/missing. can you please have a look and do the needful.
Report Description:
Please create a report that includes the number of CPU sockets, CPU Cores per Socket, CPU Vendor, Total CPU Cores. This should target all physical servers (Windows, Linux, Solaris, ESXi, Nutanix, Xen).
Ah, I forgot that CPU, etc for ESX hosts is in Orion.VIM.Hosts, not Orion.Nodes. Try this:
SELECT [Node], [Total CPU Sockets], [Total CPU Cores], [CPU Vendor], [CPU Cores Per Socket]FROM(select N.Caption as [Node], Count(N.AssetInventory.Processor.Name) as [Total CPU Sockets], Sum(N.AssetInventory.Processor.NumberOfCores) as [Total CPU Cores], Max(N.AssetInventory.Processor.Manufacturer) as [CPU Vendor], Sum(N.AssetInventory.Processor.NumberOfCores)/Count(N.AssetInventory.Processor.Name) as [CPU Cores Per Socket] from Orion.Nodes N WHERE N.VirtualMachine.VirtualMachineID is NULL Group By N.Caption HAVING Count(N.AssetInventory.Processor.Name) > 0 UNION(SELECT H.HostName as [Node],H.CpuPkgCount as [Total CPU Sockets],H.CpuCoreCount as [Total CPU Cores],H.ProcessorType as [CPU Vendor],H.CpuCoreCount/CpuPkgCount as [CPU Cores Per Socket] FROM Orion.VIM.Hosts H)) AS PhysicalORDER BY Physical.Node
This will select any ESX hosts and any nodes that do not have a counterpart in Orion.VIM.VirtualMachines.
