I am facing the prospect of installing MS SQL Server 2008 with no input from a SQL guru. I want to make sure I get all of the various settings correct for use with SolarWinds applications.Does anyone know of a good document that I can use as a checklist? Ideally, the reference would cover not only SQL installation, but then also deal with the specifics of optimizing SQL for the SolarWinds database.
I would appreciate any help very much.
