Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Orion and Cirrus on Same Box
direland69
Is installing Orion and Cirrus on the same box supported? I currently have Orion and Cirrus on the same server here. Yesterday, I upgraded Cirrus to 3.5 (Orion version was 8.0.1). After upgrading Cirrus, I am no longer able to open Map Maker. Trying to do so produces the following error...'
Run-time error '430':
Class does not support Automation or does not support expected interface
I have tried uninstalling both products and reinstalling just Orion 8.0.2. Still no go. Plus, now when I try to run the Orion install, I get errors referring to OLE2.DLL during the registering components process.
Seems I had a similar issue when I fisrt installed Cirrus on this box (3.0 then). It hosed up my server so bad that I finally had to re-image it. I'm afraid I'm heading down this path again.
Find more posts tagged with
Accepted answers
All comments
FormerMember
Just got this from support
If Cirrus 3.5 has been installed, this is to do with a copy of a dll file being registered in the wrong directory. File name is SWDiscoveryServices8.dll
To fix this go to a DOS prompt and do the following…this will unregister it in the wrong subdirectory and re-register it in the correct subdirectory:
C:\>cd program files
C:\Program Files>cd SolarWinds
C:\Program Files\SolarWinds>cd "Configuration Management"
C:\Program Files\SolarWinds\Configuration Management>regsvr32 /u SWDiscoveryServices8.dll
C:\Program Files\SolarWinds\Configuration Management>cd ..
C:\Program Files\SolarWinds>cd common
C:\Program Files\SolarWinds\Common>regsvr32 SWDiscoveryServices8.dll
Another way of doing this is:
Start > Run > regsvr32 -u "C:\Program Files\SolarWinds\Configuration Management\SWDiscoveryServices8.dll"
Then
regsvr32 "C:\Program Files\Solarwinds\Common\SWDiscoveryServices8.dll"
worked great for me.
direland69
Yep, worked for me too. Thanks!
mkocsis
I upgraded mine, too and didin't even try Mapmaker yet. When I did I received the same error. This fixed worked for me, too.
Good catch.
Michael Kocsis
Data Communications
City of Tampa
danrog
Just wondering. Have any of you tested editing a node in Cirrus after changing the dll that is registered? After changin the dll that is registered, map maker works but I cannot add/edit a node in Cirrus any longer (hangs and eventually crashes). If I revert back to the Cirrus version of the dll I can add/edit nodes but then I of course lose map maker again.
direland69
danrog,
Yep, having the exact same issue.
FormerMember
not a fix but helps out > Batches for each
www4.solarwinds.net/.../topic.asp
FormerMember
Just had exactly the same issue using Cirrus 3.5 and Orion 8.02. The fix posted by Mike McCartney worked a treat.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
