Good Day,
Currently, it appears that when a network node is added to a map file, the label for the node is tied to the System Name property. The nodes we are mapping currently are limited to 8 characters for this property, but we have created a custom property for each node called CellName within the SolarWinds structure. Is it possible to point the node labels in the Network Atlas to this custom property without having to type them all in manually?
In the example below I've got a node with the System Name of "Newhop_502". The CellName property I've defined for this node is "New Hope". I'd like to get the labels in the Network Atlas to point to the CellName property of each node without having to edit approximately 1200 labels.
Current: Proposed:
I have tried searching for an answer to this in support cases as well as here in thwack, but haven't had any success - so I apologize if this has been covered already.
Thank You,
