The current status of the polling engine is.... --->
How to evaluate whether I should add an additional polling engine.?
Thanks for help me with that.
when you have about three times its current load -- a PE supports about 12K elements and you have about 4500
to add to this; you may need an additional poller beforehand depending on your server and polling specifications.
Check the "Learn More" link next to your polling rates for some more details. (http://knowledgebase.solarwinds.com/kb/questions/3227/Poller+Status+Warning%3A+A+poller+is+either+approaching+or+in+excess+of+its+polling+rate+limit)
Basically, there is an application limit of 12,000 elements. However, that is at optimal conditions. If your server is undersized and/or your polling intervals are decreased from default, your polling rate will increase.
For instance (these numbers are made up and assume standard polling intervals):
Conversely:
Of course, this is ignoring the other polling metrics (Routing, UnDP, Hardware Health, etc.) But I don't think I have personally seen any of those be an issue. It's generally your base polling rate that you need to concern yourself with.
-ZackM
