Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Additional Polling Engine
epb3
We're looking into moving our Polling Engine onto another server. just curious if anyone knows the system requirements for it. I don't know if it's the same as the requirements for the SLX found here (
http://solarwinds.net/products/orion/sysreq.aspx
), but I would assume they'd be lower. Thanks in advance.
Find more posts tagged with
Accepted answers
All comments
ceclark
Per the online manual--
"While the SLX version is not limited in the number of elements that it can manage in terms of licensing, there is performance limitations on how many elements can be managed based on the server hardware. Current technology limits management to an estimated 6,000 – 8,000 elements per SLX polling engine."
See the details at:
www.solarwinds.net/.../AdminGuide.htm
jciancio
this may help....
www.asl-orion.co.uk/.../sizing_document.shtml
jim
vhcato
The guidelines in the link you posted are very general, and it really depends on how your environment it set up. Where you have the SQL DB, where you're hosting the web site, number of elements, and polling frquency all play a part in it. I would say that it's a good guideline for the additional polling engines as well, but you may be able to go a little lighter depending on your polling requirements.
Don't know if that really helps...
Vic
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
