Can't find the mibs so I can monitor tunnels status to trigger alarm if a vpn goes down. Would also like to graph bandwidth down each tunnel.
Gary
Hi Gary,
Have you tried to poll the following MIB?
CISCO-REMOTE-ACCESS-MONITOR-MIB :crasSessionTable (1.3.6.1.4.1.9.9.392.1.3.21)
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.392.1.3.21.1
HTH,
Yann
yea 871 on latest code says not supported, but this looks more like PP2P remote access type stuff. I am looking for ipsec Lan to Lan vpn tunnels
You should run a mib walk on the private MIB tree (1.3.6.1.4.1) to see which MIBs are supported.
This post explains how to do a MIB walk if needed:
