Hello,
I'm working on a SQL query and I'm not getting the results that I need. I'm trying to get the custom table widget to supply the component status for two different component names for the same node. I'm getting the below results, but it's showing duplicate entries.
SQL Query:
SELECT n.statusled AS 'Status',
n.caption AS 'Device',
CASE
WHEN Substring(ca.multivaluestatistics,
Charindex('A', ca.multivaluestatistics) + 4,
( ( ( Len(ca.multivaluestatistics) ) - Charindex(':',
Reverse(ca.multivaluestatistics)) ) -
Charindex(',', ca.multivaluestatistics)
- 5 )) = 'N' THEN '0 minutes'
ELSE Concat(Substring(ca.multivaluestatistics,
Charindex(':', ca.multivaluestatistics) + 1,
Charindex(',',
- 3 )), ' minutes')
END AS Age,
CASE
Charindex('C', ca.multivaluestatistics) + 6,
( ( ( Len(ca.multivaluestatistics) ) - Charindex('.',
- 5 )) LIKE 'N%' THEN '0'
ELSE Substring(ca.multivaluestatistics,
- 5 ))
END AS Count,
CASE
WHEN Substring(ca.multivaluemessages,
Charindex('A', ca.multivaluemessages) +
4, ( (
( Len(ca.multivaluemessages) )
Charindex(':', Reverse(ca.multivaluemessages))
- Charindex('M', ca.multivaluemessages) )) LIKE 'N/A%' THEN
'0 files were found in the directory'
ELSE Substring(ca.multivaluemessages,
4, ( (
- Charindex('M', ca.multivaluemessages) ) + 100)
END AS Count_Info,
n.bca_app_owner,
CASE
WHEN ad.componentname LIKE 'Custom Windows File Age%'
AND ad.componentstatus = 'Down' THEN 'Down.gif'
AND ad.componentstatus = 'Critical' THEN 'Critical.gif'
AND ad.componentstatus = 'Unreachable' THEN 'Unreachable.gif'
AND ad.componentstatus = 'Warning' THEN 'Warning.gif'
AND ad.componentstatus = 'Unknown' THEN 'Warning.gif'
ELSE 'Up.gif'
END AS 'File Status',
ad.componentname,
ad.componentstatus,
CASE
WHEN ad.componentname LIKE '%Epic BCA%'
ELSE 'Up.gif'
END AS 'Service Status',
CASE
WHEN n.bca_pcs = 'Field Services - DV' THEN 'Deer Valley'
WHEN n.bca_pcs = 'Field Services -JCL' THEN 'John C. Lincoln'
WHEN n.bca_pcs = 'Field Services - MG' THEN 'Medical Group Office'
WHEN n.bca_pcs = 'Field Services - NSSC' THEN 'NSSC'
WHEN n.bca_pcs = 'Field Services - OSB' THEN 'Osborn'
WHEN n.bca_pcs = 'Field Services - SHEA' THEN 'Shea'
WHEN n.bca_pcs = 'Field Services - TPK' THEN 'Thompson Peak'
END AS 'Facility'
FROM dbo.apm_component c
JOIN dbo.apm_componentalertvariable ca
ON ca.componentid = c.id
JOIN dbo.apm_application a
ON a.id = c.applicationid
JOIN dbo.nodes n
ON n.nodeid = a.nodeid
JOIN dbo.apm_alertsdata ad
ON ad.nodeid = n.nodeid
WHERE n.caption NOT LIKE 'ARCHIVE-%'
AND n.bca_app_owner = 'EMR Ambulatory'
AND n.statusled != 'Unmanaged.gif'
ORDER BY ( CASE
WHEN n.status = 'Down' THEN 1
WHEN ad.componentstatus = 'Down' THEN 2
WHEN ad.componentstatus = 'Critical' THEN 3
WHEN ad.componentstatus = 'Warning' THEN 4
WHEN ad.componentstatus = 'Unreachable' THEN 5
WHEN ad.componentstatus = 'Unknown' THEN 6
WHEN ad.componentstatus = 'Up' THEN 7
END ) ASC;
