I have a major issue at the moment in that our Solarwinds server was only configured to hold the last 30 days worth of data fully and then it seems to give a daily avergae before the 30 day period for all counters.
I need to find out the CPU history of "Node A" between some dates that go back a fair way. I have the NPM SQL backup's so i want to restore them to a new database on our SQL server and then write a quick SQL query in the form of
Select CPU % between date x and Date Y every 10 mins for Node A
Does anyone know how I can accomplish this or if there is a reference guide from Solarwinds relating to the fields and tables that i can qery in order to get this information?
I tried to do a SQL trace when I do it on the current site but we have so much going on there that I can't find the SQL query that is executed in the trace logs.
Once I get the information I can then plot the graphs myself in excel so I am kind of hoping I will get a table with date/time in one column and CPU % in the other column.
thanks,
Paul
