After a otherwise succesfull upgrade to NMP12.4 etc, I seem to have many "new" issues, both with things stopped working, but also thing new in NPM not working as expected.
Here is one:
Entering to EDIT NODE, will remove the "Web Brower" URL info, otherwise showing in the Node Detail widget
I tried both Firefox and Chrome ...
Before EDIT NODE:
Click EDIT NODE (could be change something or not change anything) and submit
This is how the section looks in EDIT NODE
so the Variable tag is missing !
I had this in my buffer, so I can write it back in :
But REALLY ... Comon Solarwinds, you can do better, than breaking stuff that used to work before upgrades !
How to fix this ??
