quote:Originally posted by Network_GuruIf you have two links between OSPF areas or BGP AS' it's most likely due to routing.If you don't have some kind of load sharing setup, all the traffic in one direction has moved to the other link.-=Cheers=- NG ~seek & ye shall find---> [url="http://www4.solarwinds.net/SolarWindsForum/search.asp"] <---no need to wait for answers~
Check the node and interfaces from the Node Manager, make sure they have all boxes checked.
Have you tried to remove and re-add the node and interfaces from Orion, or tried to change the SNMP version from v2c to v1?
