Hi everyone,
which variables are valid for using in the 'ODBC User Experience Monitor'?
I have to monitor a lot of Postgres databases and I don't want to change the Connection String and the Sql Query of each component.
For this example I have an application called 'postgres'
Default Setting of the components of this application is:
I want to replace the highlighted fields with a variable. It doesn't have to be application name like in my example, it could also be another field (It would be a lot better if it is not the application name for sorting reasons). I tried this but I don't work:
@aLTeReGo mentioned in this post available variables for the HTTP monitor https://thwack.solarwinds.com/t5/SAM-Discussions/List-of-variables-useable-in-SAM-HTTP-monitor/m-p/239104
Is there also a list of available variables for this type of monitor?
Greetings
Dominik
