Maybe its me (again!) but after upgrade to 10.1.1 the universal device poller is no longer available?
The admin guide refers to it so i assume it has not been removed..
anyone had similar?
It should be there. If you want to check the folder to see if maybe the shortcut has been removed it should be located here;
C:\Program Files\SolarWinds\Orion\NPM\
mezdem--
Your last post was blank--can you repost your question, please. I'm going to delete the blank one.
M
If you're going by using an older SHORTCUT link then yes it's been changed and that may emulate the loss.
You'll have to locate it off the Program list and re-create any future Shortcuts or else run it from the new list.
It is still there. On the start menu, the link has moved from being directly under "SolarWinds Orion" to being under "SolarWinds Orion\Network Performance Monitor".
