I upgraded to 8.5 yesterday from 8.0, and went from netflow 2.0 to 2.2. I've had nothing but issues since. My first issue is that my network maps no longer show up properly. Before the upgrade, I had a map of the US with lines and embedded maps. The only thing I can see now is a big gray box with my lines and a few labels. I pull up the map in mapmaker and everything looks great. I tried modifying the view by re-adding the map, creating a fresh map, and changing to an existing map. Nothing works, I can only see the big gray box of nothing. I opened a ticket with support, but no solutions yet.
The other issue I am having is with netflow. If I click on a node on my website that has a neflow data because netflow is enabled on it, the node details come up fine. If i click on anything else, like a server, that obviously doesn't have netflow data, i get a nasty error message listed below. I should have waited awhile before i upgraded.
Orion Website Error
An error has occurred with the Orion website.
Additional Information
System.Exception: Unable to create TopApplicationsReport. ---> System.Data.SqlClient.SqlException: Invalid object name 'NetflowDetail_5429'.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj)
at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj)
at System.Data.SqlClient.SqlDataReader.ConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader()
at SolarWinds.Netflow.Reporting.TopApplicationsReport..ctor(Int32 rowCount, FilterCollection filters)
--- End of inner exception stack trace ---
