I have a Linux/Unuix Script Monitor component that is alerting when it should not be. If I run the script directly on the server, it returns promptly with a success value. If I edit the application monitor for that check on the server in question, then run a test, it just hangs, never returning.
I have checked /var/log/waagent.log on the server, and there doesn't appear to be anything in there regarding the check.
I am still fairly new to SolarWinds/SAM, so I am at a loss as what to do. Where else would I look to figure out what is going wrong?
Thanks in advance....
