Node discovery and managment has come a long way since the early days of Orion.
Being able to select and edit multiple elements at once through the web gui is a huge benefit.
However, I wonder if I am missing something here.
Please let me know.
Firstly;
I'm using the Node discovery to import new nodes and their associated interfaces into a new Orion install.
I have 260 switches to import, but only want to monitor the Fa0/1 & Fa0/2 ethernet interfaces (regardless if they are up or down).
I end up importing all interfaces and then deleting Fa0/3-48 manually after they are all imported. Am I doing this right?
Secondly;
Using the Manage Nodes page > Interfaces, I want to delete all unknown and down interfaces from a group of nodes.
I can't find the filter that allows me to select all down or unknown interfaces. Or is there a way to sort by interface status?
What am I missing?
I realize much of this can be done using custom SQL queries, but for the average user, I would think these features/options should be available in the gui?
