I upgraded to 9.1 from 9.0 (Latest SP)
Following Problems identified:
- Report on Front Page does not show up consistently
- Map on Front Page does not show up consistently
- When drilling down into maps they dont always show
I must admit that these symptons are generally not specific to the upgrade as this issue has
been ongoing for a number of years and generally seems to stem from the COM+ process using to much memory possibly. As when you delete this process or multiple processes if you have changed your settings according to solar tech support the maps and report return. Before the upgrade the maps we not disappearing but the reports would occassionally however since the upgrade the maps have not been showing up more frequently and also on the child objects which was not occuring (as far as I can remember with ver 9.0)
Not sure if anyone else has a similar experience
Regards
Miron
