Dear All;
Now i using Solarwind NPM 11.5.2 , i want to install Storage Resource Manager.
Which version is suitables NPM 11.5.2.
with regards
KyawZayOo (David)
NPM 11.5.2 is compatible with SRM 6.2.
You can use the SolarWinds Orion Installer (Use the SolarWinds Orion Installer to install or upgrade Orion Platform products - SolarWinds Worldwide, LLC. Help and S… ) to check compatibility or your upgrade path (without actually installing), and you can also use the SolarWinds Product Upgrade Advisor - SolarWinds Worldwide, LLC. Help and Support .
