Last week I setup some very simple database availability testing for oracle. I installed the client and configured the monitoring without issue. My NOC has reported that these monitors sporadically change to unknown. I was able to catch them while unknown and I show a very interesting message.
The Oracle Client software must be properly installed to use the Oracle QA Monitor. Component uses following Oracle Client Driver: ODP_NET. This particular Oracle Client software can be downloaded from the Oracle ODP.Net webpage. Underlying exception message is: 'Exception has been thrown by the target of an invocation. (Inner exception message is: The type initializer for 'Oracle.DataAccess.Client.OracleClientFactory' threw an exception.).'. |
It's as if the client isn't installed. Like I said the monitor does work but we appear to get this error at random. This morning all my Oracle monitors failed around 7:30 and returned to normal around 8:50 (while posting this message). I can find nothing in any of the logs pointing me to the problem and nothing has changed on this server.
Any thoughts or suggestions?
I'm on the following versions.
Orion Core 2011.2.2, SAM 5.0.1, IPAM 3.0, IPSLAMGR 3.5.1, NCM 7.0.2, NPM 10.2.2, SEUM 1.5.1, UDT 1.0.1
