Cant get advanced sql reports working with webinterface sql filter like simple reports, is this missing?
ThanksPål
I don't believe so as the select statement is set and you are just adding [to] the "WHERE" clause
Ok, suspected that but I see no reason why this could not be done programatically with advanced report also.
Hi
a script that can send an sms (message by phone) during an alertI do not use and I can not use the software Orion NCM Web Console Is there another solution that allows you to do what I seen
Can you give me more information on Solarwinds Alert Manager (win32 app) on the use of script and receiving sms message by phone thank you
Bilel
Please delete your post Bilel, your question makes no sence in this thread.
bilel,
I have answered you on this same question here. Please keep your questions limited to a single thread.
Thank you,
Danielle
