Our Network team wants to be alerted whenever their primary circuit fails over to a backup. I have played with the Orion Advanced Alert for 'Alert me when a Neighbor down', which I've been told should handle this issue, but haven't had a 'live test' yet to see if it works when primary fails to backup circuit. Here's how I have it configured. I select the router in question, followed by the trigger conditions.
The team previously used Nagios in the past to run a trace route and if it see's a change, then would alert if it did. I'm thinking this property 'Routing Neighbors' will handle it, but not sure if I need to identify the exact circuits in question?!?.
Can someone share insight if this looks to be the best approach to this problem, or other strategies?
