When adding a device via SNMP Orion walks SNMP using MIB II standard and provides the options to select what to monitor (interfaces, CPU, memory, etc). I would like have the same process performed for vendor specific MIBs when adding a device. Browsing through vendor MIBs through UnDP shows that Solarwinds does have a lot of vendor specific MIBs in their database. I think it should be simple to to the through a process such as: a device is added, MIB II standard information/options are discovered including the vendor/device information, those vendor MIBs are retrieved from the MIBs.cfg database and used to walk SNMP, vendor informations/options are discovered as well, resources selection window appears with MIB II standar AND vendor specific MIB objects available for selection. The ability to add any non-included vendor MIBs to the MIBs.cfg database will also increase the functionality of the product with this process.
