Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Nightly maintenance
filipv
I don't want nightly maintenance. I want manual maintenance only. How do I disable automatic nightly maintenance?
Find more posts tagged with
Accepted answers
All comments
Josh_Stephens
Filip,
There are a couple of ways of doing this. First, you can rename the Database-Maint.exe application. By renaming this application the job will no longer by automatically started. Also, you can move or rename the NetPerfMon-Nightly.Miantenance file. This will have the same effect.
Please let us know if we can provide any additional information or assistance.
Sincerely,
Josh Stephens
R&D Team
SolarWinds
vaibhav14
Another question along similar lines. Do we need Task Scheduler and SQL Server Agent running on the Orion NPM Server at all?
Or does Orion NPM have its own scheduling engine. I don't see any jobs in either Scheduled Tasks or within SQL but just need a confirmation so I could decide whether to keep these services running on the server or disable them.
Vaibhav
Josh_Stephens
Vaibhav,
There are 2 scenarios where you would need these components on the Orion server. First, for the Windows Task Scheduler, if you're using the Orion Report Scheduler, it uses this component.
Secondly, if you are running SQL on your Orion server you will want the SQL Agent on the box and you'll want to define some SQL jobs to backup and reindex/shrink your database.
HTH,
Josh Stephens
SolarWinds R&D
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
