i have nearly solved the problem to display all policy violation in a resource. How it is possible wished in the idea: https://thwack.solarwinds.com/ideas/1666
Unfortunately it isn't really nice but you get all the information you want to see (just like me).
For a simple summary overview you have to add the resource "custom swis query":
edit this resource and paste following sql-statement into the field: SELECT pr.Name, rv.Info, rv.Warning, rv.Error FROM Cirrus.PolicyReportViolations rv, Cirrus.PolicyReports pr where rv.ReportID=pr.PolicyReportID and rv.TimeStamp > GETDATE()-1
(perhaps you want to expand it with that: and pr.Granuality!="Weekly")
You can choose the rows that have to be displayed with a simple counter at the bottom of the query field.
If you are done with it then you get something like that:
Name Info Warn Crit
report1 1 2 1
report2 2 0 9
and so on
But the report-names are not a link (href) to the specific compliance policy. Sorry it is only a table but you can sort it.
If you want links to the specific compliance policies you have to use a resource called "custom html" and in this you can only use javascript to initialize a database connect.
If there is an other way please tell me.
For myself I only use a "custom query" to display the policy violation summary and below that resource a add an other resource "custom html" and pasted manually all links to the compliance policies.
For further question do not hesitate and ask me.
Kind regards,
Flo
