Description
This procedure, when executed, will return all SQL statements for the given date range and program ordered by wait time. The name of the program should match content of the Programs tab within the Ignite GUI. See comments inside the procedure for more details on the parameters and methods for calling. Install the stored procedure into the Ignite repository database.
Stored Procedure
IF (SELECT COUNT(*) FROM SYS.OBJECTS WHERE NAME LIKE 'TopSQLforProgram') = 1
DROP PROC TopSQLforProgram
GO
-- TopSQLforProgram PROC
-- PARMS '@FROM_DATE';, '@TO_DATE';, '@DBNAME'; , '@PROGRAMNAME';
-- EXAMPLE:
-- EXEC TopSQLforProgram '2008-12-13 12:00', '2008-12-24 12:00', 'WT10A_DEMO', 'sqlplus.exe'
CREATE PROC TopSQLforProgram
(@FROM_DATE VARCHAR(16), @TO_DATE VARCHAR(16), @DBNAME VARCHAR(50), @PROGRAMNAME VARCHAR(50))
AS
DECLARE
@SQL VARCHAR(4000),
@DBID VARCHAR(3)
BEGIN
SELECT @DBID = ID FROM COND WHERE NAME = @DBNAME
SELECT @SQL = 'SELECT HASH_OR_NAME, TIMESECS FROM ( ' +
'SELECT ISNULL(N.NAME, SW.IZHO) HASH_OR_NAME, SUM(SW.QP/100) TIMESECS ' +
'FROM CONSW_' + @DBID + ' SW LEFT OUTER JOIN CON_SQL_NAME N ON SW.IZHO = N.HASH ' +
'INNER JOIN CONPR_' + @DBID + ' PR ON SW.UDPW = PR.ID ' +
'WHERE SW.D BETWEEN ' +
'CONVERT(DATETIME,' + '''' + @FROM_DATE + '''' + ', 101) AND ' +
'CONVERT(DATETIME,' + '''' + @TO_DATE + '''' + ', 101) ' +
'AND UPPER(PR.NAME) = UPPER('+ '''' + @PROGRAMNAME + '''' + ') ' +
'GROUP BY ISNULL(N.NAME, SW.IZHO)) TOT ' +
'ORDER BY TIMESECS DESC'
EXEC (@SQL)
END
GO
