I want to use Scripts which use CDO. Orion is running on a Server 2008 R2 x64, but CDO is only available as 32-bit download.
If I run the Script directly on the Orion Server, I have to use the cscript.exe from the c:\windows\syswow64 folder instead of the c:\windows\system.
When I use my Script in APM and chose vbscript as Script Engine it seems to run in 64 bit mode and is unable to create a cdo session.
Is there a value in the Scriptengine field I can use to force APM to use the 342-bit cscript.exe to execute my script or another way I can solve this problem?
Thanks in advance!
