Need your recommedations on what module of Microsoft SQL 2005 training would I take inorder for me to understand and manage effectively Orion and its modules?
Here are the training module
Highly appreciate any response
like mentioned before, depends on what you are tasked with/trying to accomplish as well as what your background is...
if you've had prior programming and underestand SQL basic concepts you'd probably be bests served by taking the "writing queries using T-SQL"
good luck
If you have little/no experience running MS SQL servers and you are going to be the one responsible for its care and feeding (a good base level of understanding is better than looking at it as a black box/magic):
If you're implementing APM and will need to write/support SQL queries for APM components (and/or are using MS SQL Reporting Services):
If you are planning on augmenting Orion graphs and reports with MS SQL Reporting Services:
Maybe if/when you plan on upgrading the database that you're running Orion on from MS SQL 2005 --> MS SQL 2008
Makes sense. But it appears that I need to take all of the module
