Hi all,
We are about to use a dedicated sql 2005 database for our MOM installation and our Orion installation.
We will use separate instances and vm ware on this server.
I can not find any documentation for the SQL installation for solarwinds.
The question I have is when MOM is installed you have to do the following things on the SQL installation that
are possibly different to what Orion Requires:
1. Select SQL Server Database Services, Reporting Services and Workstation components, Books Online and development tools. Leave all other components unchecked followed by clicking next.
2. Select the Use the built-in System account ‘Local system’ followed by clicking next.
3. Select SQL collations (used for compatibility with previous versions of SQL Server). Make sure that ‘Dictionary order, case-insensitive, for use with 1252 Character Set’ is selected followed by clicking next.
I do not know anything about SQL and as I can find no documentation on the type of SQL installation that
Orion requires I can not say if Orion will still work under this type of SQL installation.
If anyone has any knowledge on SQL with Orion that would help me very much
Sam
