Hi, we have this issue where our SQL Servers do not appear to be reporting memory correctly in the Memory used section of SolarWinds. However, if we look at Physical Memory usage, it appears to be reporting correctly but is always reporting the same. Why does it always show under 5% on the Memory Used? Is this because the Memory used is showing what the OS is using and the Physical Memory is showing what is allocated to SQL?
